CSGO Game Issue HELP PLEASE
supermantroll
35
Hello to whom ever is reading this. I mostly play CSGO and I'm currently having troubles playing the game. When ever I try to join a game and or server I always get kicked with this message "You cannot play on secure servers for one of the following reasons: An issue with your computer is blocking the VAC system. You are Unable to Maintain a stable connection to VAC System You are running software that is modifying the game or incompatible with VAC.
I've tried everything, Im just bumped and I'm out of ideas I've reinstalled steam i reinstalled the game, I put all of the commands into CMD that steam told me to do. If anyone can help I'd appreciate it, thanks!
EDIT: I just tried going back on my main computer which the problem started on and it didn't work, and the laptop I'm using now didn't have the problem that Im having on my computer but I just tried join a game on the current laptop im on and I just got the exact same message. Which is really annoying
Basically software on your computer is blocking vac. It can be your virus software, firewall, and others. You may have to open ports for csgo on your router or firewall software. I suggest change your virus software to avast and open the ports needed. Try turning off firewall software to test. You may have to restart you computer each time you get vac warning. Its only way I know to reset the vac kick out.
https://steamcommunity.com/app/730/discussions/0/35222218619577126/
If you like custom CSGO maps check out my workshop.
http://steamcommunity.com/profiles/76561197966464007/myworkshopfiles/
Latest posts
