Question Curious about Portable Power Station
tooncake
31
Can a portable portable station (like Jackery) can be used for an emergency power supply? Like a sudden blackout and you only need to access your desktop / pc to clear things up like work-related stuff and shut it off eventually?
It would depend on the size of the unit and the power requirements of your desktop. But, if you have a 2000W unit (over $1300 to purchase) then you should be able to run a desktop for a while. But you also have to have power protection for your network. And if the outage is widespread your ISP feed might be down.
Reactions: tooncake
Currently into consideration of getting one. Thanks for this!
If budget is an issue a much cheaper (but louder) option would be a UPS and small gas generator. Just run the cord to the generator out a window if needed, never run a generator or any other gas engine indoors.
Of course. Just a few points to consider from some materials (YouTube, etc) I've looked into.
  • Make sure the power station provides enough wattage for your equipment as smaller ones don't output as much. If you don't know what you need, get a Kill-A-Watt or a similar device and take some readings on what you'd need.
  • If you're expecting a blackout to last longer than say 12 hours, invest in a solar panel for it as well. The companies off the top of my head that sell kits are Anker and Bluetti.
    • Just note that solar panel ratings are only good for being in the Tropic of Cancer/Capricorn in the peak of summer at noon and get worse the closer to the the poles you are.
    • Power output also may appear weak. For instance a panel that's meant to be "portable" can have the same foot print as a desk but is only rated for 100W.
  • Make sure the battery chemistry is lithium iron phosphate, or LiFePO4. These have a higher endurance rating and don't mind being kept at 100%, unlike lithium ion based chemistries.
EDIT: If you need something that keeps things alive when a blackout hits, then you need a UPS. AFIAK, you can't use power stations as a UPS.
