Hello, my name is Christian.
This is my first time building a PC-and I want the best parts.
I currently have an Alienware x51-but that doesn't matter today.
The Epic Build as I call it is as follows.
CASE: Azza Genesis 9000B (I have already ordered this)
POWER SUPPLY: Seasonic Platinum-1000 (I have also already ordered this)
GPU: EVGA GTX 780 ti classified kingpin
CPU: Intel i-7-4770k quad core processor (3.5GHz)
MOTHERBOARD: ASRock EATX Z87 Extreme 11/AC
RAM: Corsair Vengeance Pro DDR3-2400 4x8 GB
STORAGE: 1 Crucial M500 960 GB 2.5" & 2 Western Digital Velociraptor 1TB 10000 RPM
OPTICAL DRIVE: 2 LG electronics 14x Blu-Ray Burner Re-Writer WH14NS40
WIRELESS CARD: ASUS PCE-AC68 Dual-Band Wireless PCIE adapter 802.1a b g n ac
SOUND CARD: Creative Sound Blaster ZxR SBX PCIE Gaming Sound Card
SYSTEM COOLING: I will be using a fully custom water loop with a 480mm radiator.
Here are my questions and problems:
1. My first and most important problem is that my processor doesn't allow RAM with voltage above 1.5v (my ram takes 1.65v) I would like to keep the same RAM, processor, and motherboard. If that isn't possible however please give recommendations on different motherboards/RAM/CPUs.
2. I would like to make sure I have enough space for the Sound Card, Wireless Card, and GPU all on the motherboard.
3.Recommendations on changing of any of the parts.
4. Recommendations on websites where I can purchase water cooling parts.
Thanks, I really appreciate the help!
