Hello,
My wife has been wanting to upgrade to a curved monitor for a while so I think I may surprise her with one.
I’ve looked at several different monitors but the options and features are a bit overwhelming. I’m hoping someone can answer a few questions for me and perhaps make some suggestions.
Budget-$500+/-
Size - she currently uses a 27” LG non-curved regular monitor. Everything I read says to go with widescreen (makes sense) if you get curved. The most common sizes seem to be 32 and 34. That doesn’t seem like a huge jump to me but I’ve never seen one in person. Do you think 32/34 would be a noticeable difference for someone use to at 27”?
Resolution - 3440x1440, 2560x1440, 1560x1080, etc. The current monitor is 1080p. I just put an RTX 2070 in so I think something higher wold be okay. Worried that anything below 2560 will cause the image to look stretched?
Refresh Rate- current monitor is 60Hz. She’s not an FPS freak and usually sets vsync to 60. Am I correct in understanding that anything over 60 is a waste if you do this? Would this also make anything with G-Sync useless?
Brand - Always had good luck from LG and Dell but open to anything.
Any advice is much appreciated.
Budget-$500+/-
