Question Custom build compatability + Case recommendation
Aug 20, 2020
5
Hey there I am looking at getting this current build for 1080p 60fps gaming using my old gtx 970;
-MSI B450 TOMAHAWK MAX
-Corsair RM650x 650W Modular 80+ Gold PSU
-AMD Ryzen 5 3600 3.6GHz 6 Core (Socket AM4) CPU
-Corsair Vengeance LPX 16GB (2x 8GB) 3600MHz DDR4
-Asus GTX 970 Strix (from previous pc)
-Samsung 970 EVO Plus 250GB M.2-2280 SSD (For OS)
As far as I'm aware all of these products are compatible but just wanted a confirmation on here before I go ahead as I really don't have the time or patience to research all the various products in the market.
I am still deciding on a good case that would be compatible with this build and was wondering if anyone could recommend me one, I am not after anything flashy just a simple black case that gets the job done.
Case budget is £50-£70
If anyone can spot any potential problems with this config please let me know :)
Cheers
Aug 20, 2020
5
Overall budget is £650 (saving money by using my old graphics card) what's the reasoning for the b550 over b450? It''s a fair bit more expensive from what I could see
logainofhades
B550 has PCI-E 4.0, for graphics, and the top M.2 slot. The chipset lanes are 3.0 instead of 2.0. Future CPU support could be better as well.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor (£164.97 @ Amazon UK)
Motherboard: Gigabyte B550 GAMING X ATX AM4 Motherboard (£131.26 @ More Computers)
Memory: Crucial Ballistix RGB 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory (£89.99 @ Amazon UK)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive (£95.00 @ Amazon UK)
Case: Lian Li LANCOOL II-X ATX Mid Tower Case (£77.11 @ CCL Computers)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply (£79.98 @ Amazon UK)
Total: £638.31
Generated by PCPartPicker 2020-08-20 17:36 BST+0100
logainofhades
You would be able to use it, but the drive is overly expensive, for just a gaming rig. Games don't take advantage of such speeds either. Sata SSD's are plenty fast enough, but NVME drives, like the Intel 660p, and Crucial P1 makes buying said drives kinda pointless, unless you have a system that lacks an available, and compatible M.2 slot.
