Custom Build Help
Opjesus
Commendable
Dec 5, 2016
4
Hi guys and girls. I'm trying to build a custom computer but i am new and don't know my way around them very well so i came here to get some help. I am trying to build a computer specifically for programming and playing some games on the side. (e.g. rainbow six siege, fallout (series), witcher 3 etc) My budget is around $1500-$1600. Here are the Specs of what i got so far. Thank you in advance.
Case:
Cooler Master N400 NSE-400-KKN2 N-Series Mid Tower Computer Case with ATX Motherboard Support, Multiple 240mm Radiator Support, and Ventilated Front Panel
Motherboard:
Processor:
Intel Core i7-6700K Skylake Quad-Core 4.0 GHz LGA 1151 91W BX80662I76700K Desktop Processor Intel HD Graphics 530
Graphics Card:
EVGA GeForce GTX 1050 Ti SC GAMING, 04G-P4-6253-KR, 4GB GDDR5, DX12 OSD Support (PXOC)
Sound Card:
Creative Sound Blaster Z PCIe 116dB SNR Gaming Sound Card with 600ohm Headphone Amp and Beamforming Microphone
Primary Hard Drive:
SAMSUNG 850 EVO 2.5" 250GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E250B/AM
Data Hard Drive:
TOSHIBA DT01ACA200 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
Power Supply:
EVGA SuperNOVA 1000 G2 120-G2-1000-XR 80+ GOLD 1000W Fully Modular Includes FREE Power On Self Tester Power Supply
Optical Drive:
Fan:
Corsair Air Series AF120 LED 120mm Quiet Edition High Airflow Fan Twin Pack - Red (CO-9050016-RLED)
Monitor:
Atron Vision AVF240 24" 144Hz Gaming Monitor - 1920 x 1080, 1ms(GTG), 80,000,000 : 1, Overclockable up to 185Hz, Flicker Free, Low Blue Light, 3 Line of Sight, Remote Control for Monitor
Memory Module:
CORSAIR Vengeance Pro 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2800 (PC3 22400) Desktop Memory Model CMY8GX3M2A2800C12R
And thank you again for helping me out.
The i7-6700k is overkill for the games you will play. I suggest getting an i5-6600k which is still overclockable. Also, you don't exactly need a 500 GB SSD unless you will store your games there - which isn't the case here as you have a 2 TB Hard drive. I think a 120 GB or 250 GB will do just for putting in the OS and crucial programs. By lowering the budget on CPU and SSD, you could actually buy a better GPU like the GTX 1070 (perhaps even a GTX 1080 if your budget still allows it) that will be able to handle the 144Hz monitor perfectly. And also, do you really need a sound card? You could just get a really good headset instead and save more money.
you should look at something like this:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($329.88 @ OutletPC)
CPU Cooler: Noctua NH-U14S 55.0 CFM CPU Cooler ($64.99 @ Newegg)
Motherboard: Asus Z170 PRO GAMING/AURA ATX LGA1151 Motherboard ($153.99 @ Jet)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory ($93.99 @ Jet)
Storage: Crucial MX300 525GB M.2-2280 Solid State Drive ($124.99 @ B&H)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card ($384.99 @ SuperBiiz)
Case: Fractal Design Define S w/Window ATX Mid Tower Case ($69.99 @ Newegg)
Power Supply: Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Newegg)
Monitor: Asus MG248Q 24.0" 1920x1080 144Hz Monitor ($279.99 @ Newegg)
Total: $1592.80
You don't need sound blaster.
the 1050ti is too weak
the 1000Watt PSU is a serious overkill
the monitor you selected, I have no idea what it is and how much it cost, so i just put something similar 1080p@144Hz.
The i7 is exactly what needed for 144Hz monitor.
i5 with whatever overclock will be limiting perfromance in quite a few games. those CPU intensive games will not cross the 100-120 FPS even though GTX 1070 is capable (~70% GPU utilization)
Thank you very much on the very quick reply. I chose to use the i7-6700K because i have heard many things that could go wrong with overclocking and i did not want to the chance of breaking my new computer from my lack of knowledge on overclocking. Also If i did not look to overclock the i5-6600k will it still be able to run the said games and programs?
Thank you for the quick response.i will use this list to see what i can change on my build. btw is the sound card not needed to use head sets/phones or do i just need a head set and not a sound card
1. Modern motherboards have on board sound card. Decent boards like the one i listed have good onboard sound card.
2. Headsets that connect via USB, do not use computer audio card, they have their own.
Ok i see. this means i won't need one since i have a USB headset already. thank you very much i did not know some had built in sound cards and they are not needed if you have a USB headset/headphones.
