Custom build PC help
are you really stuck on amd? I have the 8350 theres no reason to get a 1060 graphics card with this cpu as the cpu will limit you. you could save money here and get a ssd if your going to stick with amd build.
you could get better performance out of an intel cpu then the amd. plus with the right motherboard still be able to upgrade it later all within your budget.
an i5 6500 only cost about $40 more but will offer you alot better performance then the fx8350.
also you could go with an i3 6300 which is cheaper then the fx with on par performance and later on upgrade to a better cpu.
http://cpuboss.com/cpus/Intel-Core-i3-6300-vs-AMD-FX-8350
this is 1.20 over budget but will be a better PC
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($194.88 @ OutletPC)
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard ($92.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory ($49.00 @ B&H)
Storage: PNY CS1311 240GB 2.5" Solid State Drive ($64.99 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.49 @ OutletPC)
Video Card: MSI GeForce GTX 1060 6GB 6GB 6GT OC Video Card ($249.00 @ B&H)
Case: Corsair SPEC-02 ATX Mid Tower Case ($59.99 @ B&H)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($54.99 @ Newegg)
Optical Drive: LG GH24NSC0B DVD/CD Writer ($15.88 @ OutletPC)
Total: $831.20
Generated by PCPartPicker 2016-11-01 15:41 EDT-0400
way to go niklas that's what I'm talking about.
OP this would be better then your fx build.
