Custom build pc powering on, but no display, no BIOS, no monitor beep.
joecutting
Commendable
Mar 7, 2016
7
I custom built my own PC back in 2011, and it has been working perfectly ever since.
The other night it decided to switch itself off, and when I tried turning it back on, it decided it would power cycle.
I took the opportunity for a complete upgrade and replaced the motherboard, CPU, power supply and upgraded the RAM.
Now I have come to power on my "New" rig, it powers on but I have no display, no BIOS, no monitor beep.
I have stripped the PC back and tried to run with nothing but CPU fan and monitor connected, but still nothing.
    Then connected all RAM - Nothing
    Then connected GPU - Nothing
    Then SDD - Nothing
Current build:
  • Intel Core i5-4690K 3.5GHz Quad-Core (NEW)
    Corsair H100i GTX 70.7 CFM Liquid CPU Cooler (NEW)
    Asus SABERTOOTH Z97 MARK S ATX LGA1150 Motherboard (NEW)
    Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory (NEW)
    Intel 730 Series 480GB 2.5" Solid State Drive
    Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
    MSI GEFORCE N660 GAMING 2GD5/OC TF IV
    Corsair 500R White ATX Mid Tower Case
    Corsair 850W 80+ Gold Certified Fully Modular ATX Power Supply (NEW)
Was running windows 7
Any ideas on why I currently have no use?
I will try each slot when I get back from work.
I have tried starting the machine with no RAM. I still didn't get a graphics beep, I still didn't get the BIOS screen.
I believed starting with no RAM would still give me the BIOS? Is this assumption wrong?
"I believed starting with no RAM would still give me the BIOS? Is this assumption wrong?"
The system needs RAMs for POST-ing. As for beeps, is a case speaker http://images17.newegg.com/is/image/newegg/12-201-032-TS?$S640W$ connected to the board?
However, I suggest testing firstly and then deciding.
This has worked, I need to rearrange the RAM! Thank you!
The only error now is that my h100i gtx cooler is having an error on start-up.
The BIOS is not recognising the CPU cooler. It's showing CPU cooler N/A.
It is connected to the CPU_Fan socket at the top of the motherboard.
I have also attached the corsair link to the USB socket on the bottom of the motherboard.
When I turn the PC on the fans are turning and the light is on, but the CPU fan error is coming up on the POST.
They are connected as per the manual.
The pump is plugged into the motherboard directly via CPU_FAN and then the 2 fans are connected to the pump (cable off the back of the CPU_FAN socket.
So pump and both fans are going through the CPU_FAN socket.
