custom build review last minute help
Oisin_3
Commendable
Jul 17, 2016
11
Hi guys, I'm building my first custom gaming rig and I'd like your input on my bang for my buck. So straight in here's the spec sheet
PCPartPicker part list: http://uk.pcpartpicker.com/list/JvhLJV
Price breakdown by merchant: http://uk.pcpartpicker.com/list/JvhLJV/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (£220.99 @ More Computers)
CPU Cooler: Corsair H115i 104.7 CFM Liquid CPU Cooler (£117.79 @ Kustom PCs)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard (£117.98 @ Amazon UK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory (£72.98 @ Novatech)
Storage: Kingston Savage 960GB 2.5" Solid State Drive (£229.99 @ Amazon UK)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0+ Video Card (£226.99 @ Kustom PCs)
Case: NZXT Phantom 530 (White) ATX Full Tower Case (£94.99 @ Novatech)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply (£87.99 @ Ebuyer)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter (£28.20 @ Amazon UK)
Case Fan: Corsair Air Series AF140 Red 66.4 CFM 140mm Fan (£13.98 @ Ebuyer)
Case Fan: Corsair Air Series White 2 pack 52.2 CFM 120mm Fan (£19.98 @ Ebuyer)
Monitor: Asus VG248QE 24.0" 144Hz Monitor (£214.98 @ Ebuyer)
Total: £1446.84
(I'm getting my parts mostly off amazon and in euro really but these prices are very similar comes to around €1900)
Generated by PCPartPicker 2016-07-17 16:24 BST+0100
I'm not particularly concerned with aesthetics unless i can improve it at the same price (I'm using blue fans not the red and white in this part list)
My main concern is at my graphics card choice, should i go for something else for high settings on 1080p and with the possibility of later adding a second card in SLI for possible 1440p or 4k. from my research the evga gtx 970 ssc is the best choice as amd do not seem to compete on price/ temp and power as well as speed
I've put in the pricing, I'd rather not exceed £1500 or $1600 (shipping from the US will cost me a lot)
Well I've Ordered, I Switched out the EVGA GTX 970 SSC, and decided to ramp up to a Zotac gtx1070 Amp! Extreme, and I removed the monitor from my order and I will buy a 4k one at another time (worked out the same price and i have a 1080p monitor i can use in the mean time)
