Custom-Built computer, rear audio works but front doesn't
Lambury
Here's my custom-built PC info you might need:
AMD Phenom II x4 965 Black Edition Processor
GIGABYTE M68M-S2P Motherboard
2GB RAM
Windows 7 Ultimate 32-bit
So basicly, when I plug my headset into the front ports, sound and microphone, neither of them work. The front ports came with my computer case and I have plugged them into my motherboard.
Really would be appreciated of any comments :) Thanks.
Lambury
Right I got my Sound to work through my front port, but my Microphone still won't work in the front pink mic port.
John_VanKirk
1,742
176
Hello,
The 3 rear audio plugs are set up for HD audio by default. You didn't mention your case, but if you have 2 audio I/O plugs, make sure you use the HD audio one. If your case has just single wire plugs for the audio, double check they are connected correctly.
You must have loaded the Realtek audio driver to get earphone sound from it.
Go to the HD Audio Manager (sometimes there will be an icon in the system tray) where you have to configure the microphone on the microphone screen display.
It works either on the back panel, or the front I/O port, but not both simultaneously. You have to select your choice on that display screen. Also make sure the recording volume is not muted, or you won't hear any audio input.
I didn't see the Audio Manager mentioned in your user manual, so check out the display screens for information.
Hope that helps.
Similar threads
