Custom Built Firewall using PfSense in a Small Business Environment
trxnet
I have been given the opportunity to work in a Small Business Environment vs the Everyday consumer. I have experience using a SonicFirewall but I am now having to work with 2 Custom Built Firewalls using PfSense. Each have 1 Lan and 1 Wan Port. I need to physically connect these to a Cisco Router and a Server running Windows Small Business Server 2011. In the server room, there are a few patch panels, 2 managed switches the server and router. I want to ensure the proper PHYSICAL connect with this firewall to obtain Internet w/o disturbing the server as it is.
At the home office, I came across some issues with the firewall. I could access the LAN just fine until connecting the WAN and then I could no longer access the Router and would get the Microsoft Default IP address. I would have to completely reset the router to factory default to have access again. I connected an Ethernet cable running from the switch that was connected to the Router and Server running Windows Small Business Server. I was never able to connect to the internet only the LAN.
Any suggestions would be greatly appreciated!!!!!!!
trxnet
Right now I'm in the centra office which is the testing environment. There is a Cisco Router Linked to a Linkysys Switch. The Server is connected to the Router and I have two hardware Firewalls. I plugged a port from the switch into the WAN port on the Firwall. Lights up fine and I receive an IP but I can't connect to the internet. When the LAN is connected to the testing laptop I can get into the router fine but as soon as I plug in the WAN cable to the firewall I cant get into the firewall anymore and I still can't connect to the internet. Is this partly because the server is handling DHCP or something? DO I have it plugged in correctly?
