Question Custom built-in desk pc , need help.
Mar 6, 2019
Have been designing a custom desk pc, have picked out all the components I want,and drawn up and started to build the desk, it will be completely air cooled. Couple questions I have are...
  • will the fan set up be enough to cool the pc, any changes I should make(want to keep fans on sides as intakes because rgb fan lights are single sided).
  • will the components work well together?(components listed in photo) Any changes? Upgrades or better components at similar costs.
  • should I change the orientation of the components in the build?
  • any other help would be appreciated
link for photos of design
View: https://imgur.com/gallery/qPtE5ey
Thanks.
Mar 6, 2019
Looks like you will exhaust the hot air into your lap (where you sit). Is that intended?
More into my knees, pc at the moment doesn’t really push out hot air, do you see this being a problem? Any where else I should move the exhaust fans too?
Mar 6, 2019
You generally want hot air going out the back of the system, away from you. How wide/deep do you plan for the desk to be?
Desk is about 1600x 700 mm knee slot is about 250 deep. Desk will be up against a wall so decided against having exhaust fans there
Mar 6, 2019
What components do you intend to use? Need to understand how much heat will be generated.
MB- Msi-B450 carbon
CPU- Ryzen 2600
CPU cooler, wraith spire
Ram- vengeance 32gb
Gpu- msi geforce 1660 ti
Psu- Corsair cx850
Ssd- Samsung 860 qvo 1TB
Hdd- barracuda 2TB
COLGeek
The Wraith Spire will get loud when your CPU gets hot. They are decent heatsinks, otherwise, but I don't use for that reason.
Other components should be okay. My only concern is airflow as that is what keeps components cool, 6 intake fans should get enough air into the system, but only 2 exhaust fans may not be enough to move all of the air.
Are you also going to mount your PSU in such a way for it to pull cool air directly into itself and exhaust the hot air it creates outside of the desk/case (rather than into the desk/case)??
Mar 6, 2019
The desk will be quiet sound proofed, 18mm mdf, with tempered glass and 3mm galvanised steel, so as long as the cpu remains cool im happy, It won’t be over clocked and I don’t do a lot of extreme gaming etc, at most I play a game and watch YouTube, more doing this as a hobby.
How many exhaust fans should I have and where would be the optimal place to put them?
Also the psu has only 1 side with a fan and I was going to face it down so it pulls air in from the bottom of the desk? Would I be better having it face up? How does the psu emit it’s hot air? How should I mount it?
Thank you so much for all your help!
COLGeek
Modern PSUs pull cool air via their fan and then exhaust the hot air out the vents that normally are affixed to the back of a PC case. Looks like you are planning to pull cool air in, but then exhaust it into the interior of the desk itself.
Will all of the sides of the desk be sealed (except for fans and cabling)?
Also, what size intake and exhaust fans do you intent to use (i.e., 120mm, 140mm, etc)?
Yes, all sides will be sealed , except for cable entry’s and fans, I can put air vents in where ever needed , will it help if I turn the psu around so it emits the hot air into the cable zone and put an air vent in there?
COLGeek
The exhaust duct idea should help. Note, I added a question about fans above.
Seal will help with airflow, somewhat, but you do have lots of corners so that will lead to some dead zones, should be okay from the layout you are using.
Mar 6, 2019
Buy exhaust duct do you mean about having an air vent in the cable zone and having the psu exhaust into it?
Also I will be using 120mm fans
