Custom Computer Build Help
detek
So back in 2014 I bought a computer from walmart on Cyber Monday.
https://www.walmart.com/ip/Cyberpowerpc-Gamer-Ultra-Gua2000w-Deskto/34643909#read-more
Around 2015 I was having problems with the CPU fan so I bought The V8 GTS on the next Cyber Monday
https://www.newegg.com/Product/Product.aspx?Item=N82E16835103189
Now I want to replace everything besides the CPU fan, the case, and the DVD/CD tray with a budget of $600 - $800
And I want to make sure everything fits in the case i already have. (The cooler now, barely fits)
What are my options?
I forgot you could go with a CPU that doesn't have a stock cooler, but they're more expensive anyway because they are better CPUs.
CPU: Intel - Core i5-7600K 3.8GHz Quad-Core Processor ($221.89 @ OutletPC)
Motherboard: MSI - Z270M MORTAR Micro ATX LGA1151 Motherboard ($104.99 @ Amazon)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory ($75.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($45.87 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1060 3GB 3GB Windforce OC Video Card ($219.98 @ SuperBiiz)
Power Supply: SeaSonic - S12II 620W...
I can't tell if it fits standard ATX or just MicroATX motherboards. You can measure your current motherboard and compare the dimensions to ATX/mATX motherboards listed online. Or you can just stick to mATX and it will fit.
If the cooler fits now, it should fit with a different motherboard. Though some manufacturers say different motherboards can be millimeters difference.
I think you will need a new copy of Windows though. I recommend buying direct from Microsoft.
You've got a decent budget to use, I'll give some example builds:
Better CPU + GPU PCPartPicker part list / Price breakdown by merchant
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($197.28 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard ($74.49 @ SuperBiiz)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card ($269.98 @ Newegg)
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply ($49.90 @ Amazon)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($92.99 @ B&H)
Total: $806.50
Generated by PCPartPicker 2017-09-01 13:52 EDT-0400
More Drive Space + SSD PCPartPicker part list / Price breakdown by merchant
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor ($109.88 @ OutletPC)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive ($89.99 @ B&H)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($66.89 @ OutletPC)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card ($142.29 @ Amazon)
Total: $702.42
Generated by PCPartPicker 2017-09-01 13:54 EDT-0400
Minimum recommended build PCPartPicker part list / Price breakdown by merchant
Total: $591.41
Generated by PCPartPicker 2017-09-01 13:55 EDT-0400
and of course there could be a few different mix/match builds you could go with.
Total: $811.61
Generated by PCPartPicker 2017-09-01 13:59 EDT-0400
CPU: AMD - Ryzen 5 1600X 3.6GHz 6-Core Processor ($226.28 @ OutletPC)
Total: $785.50
Generated by PCPartPicker 2017-09-01 14:01 EDT-0400
Will the Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card ($269.98 @ Newegg) Work with the
" CPU: Intel - Core i5-7600K 3.8GHz Quad-Core Processor ($221.89 @ OutletPC)
Total: $811.61 " option
Yes, of course.
