Question custom duel water cooling loop price
kingWolfJM
84
I'm building a desk PC and then decided to do it custom Loop for the CPU and it custom Loop for the GPU. I've came up with about 1200 to 1300 doll hairs little over 600 per loop.
is that about right 240mm, rad 360mm, rad gpu block, cpu block, 2 reservoirs, 2 d5 pumps, Hardline tubing, fittings
You wouldn't need to do dual loops, but you can, nothing is stopping you but your budget.
Your hardware list is correct; you've accounted for what you need. If you did just a single loop for the entire system, you obviously wouldn't need 2 reservoirs and you could run a single pump, unless you wanted 2.
Your joke made me laugh.
