[SOLVED] custom gaming machine help please
1.) Swap for the Ryzen 5 3600 (if 3000 series is available, I suspect so since you can get X570.)
2.) Swap the 120mm liquid cooler for a good air cooler, which would do better for cheaper.
3.)Swap the RAM for DDR4 3200.
4.) Swap that PSU for a better quality model.
okay thank you for responding what about this
https://www.pbtech.co.nz/build/10102
i want liqud cooler because its much quieter and fancy :)
Then you should get a different liquid cooler. That one is crap. Never buy a 120mm liquid cooler unless you have a low-heat, low-power CPU to cool and you want it silent. You should get at least a 240mm radiator for any decent CPUs.
