Custom Laptop Battery
VermilionNeko
301
9
18,795
Hi
I'm looking into replacing my laptop's battery due to it not holding much charge. The wear is only about 12% from what I've read, but the charge only lasts around 1 and a half to 2 hours, even in battery saver mode.
Because it's a custom built laptop, I'm not sure what to look for or get. It was built by Cyberpower PC. Any advice or suggestions?
Thanks
Cyberpower often uses barebone shells from clevo or other manufacturers that do things like them. You just have to find the serial/model number of the battery and type it in to google (sometimes you have to leave up to four digits from the end).
See, this is where I'm confused. From what I've read, I know that the voltage needs to be the same - in this case 11.1V - and the higher the mAh is the longer its charge will last. But, what's the maximum mAh you can get for my model? I can't seem to find an answer doing a Google search. Is 5600 the highest this model will go? I'm not sure how many cells mine has either - the more cells the better...?
