Custom liquid cooling loop and components
WhereisPerry
61
In the span of a few months I am building another computer and I plan on making a custom loop,however I am non to familiar with what parts are quality and what I will need. At the moment the loop i have in mind will go something like >reservoir>pump>220mm rad>220mm rad>cpu>120mm rad>gpu>reservoir>
because of the numerous radiators I am going to assume this is somewhat of a high resistance loop. what kind of pump should i be looking at for this? stand alone with res or a combo? Also, and specific brands?
I would put the 120mm Rad after your CPU, and then the other two rads after your GPU. Also EKWB is a great company, and I would go with a D5 pump. whether you get the res as a standalone or a combo doesn't really make much of a difference.
