Custom pc biuld help
m00t123
16
Dear fellow computer enthusiasts i am thinking of biulding my first custom pc and i need some advice. I have choosen my parts but i still wish to have some feedback if my pc is actually going to work since i indeed am a pc noob.
Storage: SANDISK SanDisk SSD Plus 120GB SATA III 2.5 inch Internal SSD
RAM: HyperX FURY Series 8GB DDR3 1866MHz CL10 DIMM
Motherboard: Asus MIBG70 Socket AM3 AMD 760G/​ SB710 AM3/AM3 + Motherboard
Case: Sharkoon VS4-W Mid Tower Computer Case
GPU: AMD FD4300WMHKBOX - Piledriver FX-4 Quad Core 4300 3.80GHz (Socket AM3+) Processor
Power supply: Corsair VS550 12 V ATX Power Supply Unit
Graphics card: Gigabyte Radeon RX 460 WF OC 2GB GDDDR5 128bit 1xDVI 1xHDMI 1DP
I would very much appriciate any feedback or help!
Consider using a higher quality PSU. The Seasonic S12II can be had for around $50, and is among the better PSUs out there.
Also, the FX 4300 is noticeably slower than the Pentium G4560 in terms of gaming performance. It's not the CPU I'd choose for a new build. If you already know that and have decided you don't need gaming performance, go for it. Everything appears to be compatible.
If you are in a budget, this is a pretty good budget gaming setup:
PCPartPicker part list: https://pcpartpicker.com/list/gKKFr7
Price breakdown by merchant: https://pcpartpicker.com/list/gKKFr7/by_merchant/
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor ($59.48 @ OutletPC)
Motherboard: ASRock B150M-DVS R2.0 Micro ATX LGA1151 Motherboard ($54.99 @ Newegg)
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory ($61.99 @ Amazon)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive ($83.85 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.66 @ OutletPC)
Video Card: PowerColor Radeon RX 570 4GB RED DRAGON Video Card ($179.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($149.99 @ NCIX US)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.88 @ OutletPC)
Total: $697.82
Generated by PCPartPicker 2017-05-02 11:08 EDT-0400
If you need to shave couple hundreds $, just get a 550 instead of 570 and drop the SSD (not advisable)
There is one problem i am from the eu Slovenia and already getting the parts is a hard taski would love to swich them around but then i would have to spend twice as much
but i have decided on a new biuld
Storage: Toshiba 3,5 hard drive DT01ACA050 500 GB 7200rpm
RAM: Crucial CT8G4DFD8213 8GB DDR4 PC4-17000 Unbuffered NON-ECC 1.2V
Motherboard: Asrock H110 M DVS R3.0
CPU: Intel Pentium BX80677G4560 CPU Dual Core Kaby Lake
but getting a better psu is hard to get for a low price in my country
If you don't have the budget to get those parts AND a decent PSU, you should get a cheaper GPU or CPU and put the money towards the PSU.
A bad PSU puts the entire computer at risk of breaking. Do not skimp on it. Make room for it in the budget.
