Custom PC Build Help
fullmetal1288
14
Here's my current build:
Total: $860.91
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
Processor: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=AMD+Phenom%E2%84%A2II+X4+955+Black+Edition+Quad-Core+CPU+w&x=0&y=0
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
2x (for 8 gb) G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
Graphics: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102918
SAPPHIRE 100311-2SR Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Bluray Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136232
LG Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive Model UH12LS28 OEM LightScribe Support - OEM
Couple questions. Am I going to be fine for cooling with the fans for the gpu and cpu and the 3 case fans?
and I have had it suggested that I go for a HD 6950 instead, should I, from a purely performance standpoint?
If I did go for the HD 6950 which of these should I get:
Sapphire - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102945
HIS IceQ X - http://www.newegg.com/Product/Product.aspx?Item=N82E16814161372
Appreciate any advice or suggestions!
I think you shoul stick with the 6970 , however I do think that even though the power supply is ok I would bump it up to a 750w. You can always have too much but it sucks when you don't have enough and with any future upgtades if you already had the power supply then an upgrade would be less expensive. That is if your budget allows.
