Custom PC Build!!! (SGD1000) I need Help I'm a noob in PC stuff
ACE EA
4
I have the price list of all the pc stuff here https://www.dropbox.com/s/in6z6g0en4yjf0e/Pc%20Theme%20Pricelist.pdf
My budget for the PC Build is SGD 1000
I would like to play games like BF4 on Ultra settings if possible :/
I would like to get a Window 8.1 but I saw this Windows 8.1 Pro Student
The great features of Windows 8.1, plus easy connections to school networks and data encryption.
Important: Windows 8.1 full version is for Windows 7 users only.
Student priceSG$89.99 incl. GST
Does it meant I have to get Windows 7 in order to use Windows 8.1 Pro Student?
I really need you guys to help me in this 🙁
Mobo- http://www.newegg.com/Product/Product.aspx?Item=N82E16813130744
CPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16819113328 (I chose this one because it is a quad core and unlocked for easy overclocking)
GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814103245
RAM- http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
HDD- http://www.newegg.com/Product/Product.aspx?Item=N82E16822236625
PSU- http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028...
According to one of our moderators, you must be running Windows 7 as the Windows 8.1 Pro Student Edition offer is an upgrade: http://www.tomshardware.co.uk/answers/id-1979735/windows-pro-student-retail-version-windows.html
I would contact Microsoft and ask them if there is a Full Version of Windows 8.1 Pro Student. If there is, you don't need any previous version of Windows for that.
According to this page there is a Full Version (look at the box): http://www.microsoftstore.com/store/msuk/en_GB/pdp/productID.288533400?tid=sE2vgwDJe_dc&cid=5366&pcrid=31596416925&pkw=%2Bwindow%208%20student&pmt=b&WT.srch=1&WT.mc_id=pointitsem_Microsoft+UK_google_Windows+8+-+UK&WT.term=%2Bwindow%208%20student&WT.campaign=Windows+8+-+UK&WT.content=E2vgwDJe&WT.source=google&WT.medium=cpc
"Important: Windows 8.1 full version is for Windows 7 users only"
Where did you read that? Please provide link to relevant page.
I would recommend windows 7 64bit (IMO windows 8 is useless unless you have a touch screen) they only sell OEM versions now which isn't a big deal just means you can only get it for one PC
I'm not sure but if you see this it website says Windows 8.1 Pro Student Full version http://www.microsoftstore.com/mssg/en-sg/store/windows/288728000?icid=Nav_links_Stu_Windows8.1
do you have a preferred Intel or AMD or does it not matter?
Anything that's perform a GOOD SPEED FOR GAMING ^^
CASE- http://www.newegg.com/Product/Product.aspx?Item=N82E16811147099 (I recommend removing this PSU as the 12v rails have a low amperage you could make some money back on the case by selling it)
CPU COOLER (not needed unless you are planning on doing overclocking)- http://www.newegg.com/Product/Product.aspx?Item=N82E16835214041
Thermalpaste (not needed unless you replace OEM cooler but still recommended for maximum cooling- http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020
this build was put together with a budget in mind your total including shipping would be $608.91 USD before rebates which is around 774.64 SGD so that gives you some room to play around with stuff I hope this helps also I chose a FM2 socket because they are cheaper than the AM3 sockets but as I said since it is under your budget it gives you room to play around
