Gday, 'Im panning on building a full custom pc case made from and old military ammo tin - camo green, big metal buckles for the lid Looks sweet. The only problem I'm encountering is don't want the motherboard shorting out on the case, so I've decided to use a motherboard tray.
So if I suspend the mother board try off the inside of the case would that work you reckon?
Or are motherboard screw mounting are non-conductive so it should be safe from a short circuit?
