Custom side panel for fractal design define R5
Oct 18, 2015
28
Hello everyone,
Just a very quick and simple question. i have the fractal design define r5 blackout edition case, its been a fantastic case for the past year. My only problem is the side panel window, it functions fine, but it is made of the typical acrylic material that case manufactures use on there cases - which means it has a ton of little micro scratches on it and collects dust very easily. further still, it inst to big, so it can be hard for me to see all of my hardware sometimes. i would like to know if there is a place that i could buy a glass side panel for the case, it doesn't have to be fully glass, but mostly.
-Cheers
all the panel? haven't seen that part for that case in particular made of glass, at least form the manufacturer
perhaps remove the acrylic part and pay someone to make a identical part in tempered glass, 4 milimeters thick and install it with silicone in the frame?
a simple diy project, i'm thinking on doing it by myself for my corsair case
look at some of the pictures on this link, the ones on the bottom mostly
https://mnpctech.com/phanteks-case-mods/phanteks-enthoo-primo-clear-window-replacement-side-panel.html
yeah, i think you may be right. i looked around and hove found nothing
