custom water-cooling for GPU only
You could easily set up a separate loop for your GPU, but depending on the model of it, liquid cooling probably isnt even worth it. Alternatively, you could also go out and buy an NZXT Kraken Adapter Bracket, which would allow you to mount traditional AIO's (like another h100i) onto your GPU.
Yes you can do that go on https://www.ekwb.com/custom-loop-configurator/ or Phanteks.com but they do not have a configurator also offering gpu blocks they offer gpu block with ekwb you can have pc list and choose what parts you want to watercool. if any question you can ask me
