So the max rad size the case can support is a 240mm, which is enough for a CPU only loop.
Then I advise this kit.
http://www.frozencpu.com/products/16891/ex-wat-219/XSPC_Raystorm_750_RS240_Extreme_Universal_CPU_Water_Cooling_Kit_w_Free_Dead-Water.html?tl=g30c321s1310
Not the best radiator (would have picked the EX series, but for some reason that adds on more than $100) but it will be fine.
It will come with everything you need for a CPU only loop, except for Coolant [strike](ignore the free Deadwater, you dont want any pre-mixed coolant)[/strike] and some anti-microbial solution.
For the Coolant. Plain Distiled water is recommended and can be found at most supermarkets, is also available from FrozenCPU.
For Anti-Microbial solutions, you have a two options to choose from.
1. A Biocide, its a chemical that kills any bacteria or Algae that may grow in the loop.
http://www.frozencpu.com/products/17710/ex-liq-291/Mayhems_Biocide_Extreme_-_10mL.html?tl=g30c103s186
EDIT: Just realized that the Deadwater is actually Biocide, not a coolant.
2. A Kill-Coil, basically a small strip of silver that also kills bacteria/algae. Drop it into the reservoir and your good. This is what I use since you dont have to re-apply every time you open up the loop.
http://www.frozencpu.com/products/11441/ex-tub-705/IandH_Silver_KillCoils_-_Antimicrobial_999_Fine_Silver_Tubing_Reservoir_Strip.html?tl=g30c103s186
I also suggest you get some kind on drain valve or T-Line on the loop, makes emptying, maintaining and upgrading the loop later on a lot easier.
