E Elijames01 Commendable Mar 16, 2016 77 0 1,640 Mar 16, 2016 #1 Can I fit a custom water loop with the hard tubes inside the nzxt s340?
Solution Lutfij Apr 11, 2016 Yes, Yes you can! If soft tubing is possible in it, you can do so with rigid tubing. Just need some patience to do it.
Lutfij Titan Moderator Oct 7, 2009 66,277 8,256 185,940 Apr 11, 2016 Solution #2 Yes, Yes you can! If soft tubing is possible in it, you can do so with rigid tubing. Just need some patience to do it. Upvote 0 Downvote Solution
