Custom Water Loop Noob
MaximusPrime27th
I'm looking to create a custom water loop for myself but I have no experience whatsoever. Please help!
What I want water-cooled:
4790k
MSI GeForce GTX 970 Twin Frozr V x2
Requirements:
1x 360mm rad (27mm or less thick)
1x 240mm rad (27mm or less thick)
Black radiators
Clear water blocks (Preferably this http:// for the CPU)
Red anodized metal fittings
Clear PVC flexible tubing
Pump/Res combo (no smaller than a 140mm res)
Dark red-ish coolant
I hope this isn't too much to ask and thanks to all in advance!
first
do you have the gpus already check the pcb to make sure its a v1.1 not 1.2/3 if so the blocks will not fit.
you have the one with the red shroud correct?
second whats your budget if under 600$ with out fittings then do AIO's or stay on air
i will list parts from perf-pcs site once its not being broken again
pump http://www.performance-pcs.com/swiftech-mcp655-b-special-edition-12-vdc-d5-pump-without-speed-controller.html
with 27mm or less you have a very limited selection
rad 360 http://www.performance-pcs.com/magicool-360-g2-slim-radiator-black.html
rad 240 http://www.performance-pcs.com/magicool-240-g2-slim-radiator-black.html
cpu http://www.performance-pcs.com/ek-supremacy-evo-cpu-water-block-nickel-plexi.html
gpu http://www.performance-pcs.com/water-blocks-gpu/ek-fc970-gtx-tf5-full-cover-waterblock-nickel-plexi.html
red fittings http://www.performance-pcs.com/ek-acf-compression-fitting-10-16mm-3-8-x-5-8-red.html
tubing http://www.performance-pcs.com/primoflex-b-advanced-lrt-10ft-b-tubing-3-8in-id-x-5-8in-od-crystal-clear.html
for the pump res combo there ant many you can buy pre done thats why i listed just a pump you can buy a bitspower top and then get a pump adapter and make your own requires very little work but here is a pre made one http://www.performance-pcs.com/d5-photon-270-reservoir-pump-combo.html
top http://www.performance-pcs.com/bitspower-d5-mod-top-black-s-model.html
res/adapter http://www.performance-pcs.com/bitspower-dual-single-d5-top-upgrade-kit-250-black-pom-cap.html
coolant http://www.performance-pcs.com/ek-ekoolant-evo-liquid-coolant-blood-red-premix-1-liter.html
