Hi All,
I setup a custom water loop for the first time with my RTX 3080 and 10900k being in the same loop. Ever since the custom loop, my CPU has been getting very hot during gaming making my overclocks unstable upon reaching equilibrium.
The 10900k during isolated prolonged benchmarks hits maximum of 70 degrees, this includes cinebench, blender, AVX Stuff etc.. Works 100% fine and passes all tests.
During gaming the 10900k reaches 85+ degrees Celsius with only 25% - 35% usage and crashes 30 minutes into a game. If i have the cpu in a seperate loop like an AIO, it works fine.
The 3080 idles at 20 degrees and reaches a max of 57 degrees celcius.
Room temperature is 24 degrees
My setup is as follows:
CPU: 10900k @1.288v, 1.256v with load line calibration (Vdroop) lvl 5, @5.1GHZ
Motherboard: Asus ROG Strix z-490
Ram: Corsair Vengeance 3900mhz CL19
SSD/HDD: Corsair NVME MP600 Gen 4 1tb
GPU: RTX 3080 MSI Ventus - corsair waterblock
PSU: Corsair RM750i
Chassis: Corsair 570x
OS: Windows 11 Pro
Water cooling:
EK Classic RGB CPU waterblock
Corsair GPU waterblock made for MSI Ventus
EK SPC waterpump - at max speed (2700rpm)
360mm THIN Corsair Raditor with SP120 fans (50% max fan speed)
240mm THICK ek radiator with EK Vardar fans (100% max fan speed)
Loop setup: Pump --> 360mm rad -->240mm rad --> CPU --> GPU --> Pump
Case fans are all intake, trialed and tested intake + exhaust, all exhaust, still same results.
After searching the web, from what i can gather, the CPU shouldn't really be getting hotter at all despite being in the same loop as the GPU, have i done something wrong here?? Is it my water pump speed? Fans not pushing enough heat out?
PSU: Corsair RM750i
OS: Windows 11 Pro
Water cooling:
