Custom water loop that would fit in a Coolermaster elite 130
David Dewis
217
I have a coolermaster elite 130. I would like to put my R9 290 into the rig permanently, Currently, the GPU fits and runs, but the intense heat it puts out causes the mobo to overheat due to the poor airflow inherent with ITX enclosures. My current CPU uses a h60 with noctua fan for cooling. I'm happy to move into custom water loops, but first i need a system that fits the following criteria:
1. Radiator size is limited to 120mm.
2. there must be sufficient space for a pump & reservoir.
3. The loop must be sufficient to keep the CPU (will be an i5 4670) and GPU (R9 290) at safe temps at load.
4.Must be as affordable as possible.
5. Must be available in the UK
Consider this a challenge to all the custom water cooling ninjas out there.I look forward to your responses.
David Dewis
217
Well the arctic cooling all in one gpu cooler is thinner than the twin frozr cooler currently on the card and i still have space. A water block would be thinner still. Not sure about CPU though
CM Rene
Hi Davis,
I made it for my steambox.
I use the Cooler Master Seidon 120
and insert the Radiator in the middle of the Chassis.
http://www.pic-upload.de/view-22693707/20140113_124313.jpg.html
http://www.pic-upload.de/view-22693706/20140113_151120.jpg.html
http://www.pic-upload.de/view-22693705/20140113_172031.jpg.html
I use the watercooler for the CPU and not for the GPU.
So far I understand - you are looking for a place to Setup an Radiator - here it is.
You can connect the Radiator with your GPU-cooler instead of CPU-cooler.
B.R.,
René
David Dewis
217
Thanks for the input rene. I already have a 120mm in my elite 130 with my CPU. I wasn't sure if just 1 120mm radiator would be enough to cool both cpu and GPU. Shame in some was the case isn't just 'that' much wider. All that space where the side vents are. Begging for a 120mm rad.
ChrnoXIII
HEY!!! I ran into the exact same problem.. I have the same case and I feel like my mobo is overheating. I only have a nvidia 770 in my case... seriously considering water cooling the gpu and cpu....
how did you go with your setup
PsychoGamingLemon
647
It's not possible in this case, you will need to upgrade it to fit a custom Loop.
