Custom Watercooling loop help + questions
Michigan Tech
Commendable
Jul 18, 2016
83
Hello all,
I am build a new gaming pc in honor of the new GTX 1070. As of right now, I have these components:
Asus z170i pro gaming
i5-6600k
GTX 1070 FE
I am considering buying the Silverstone SUGO SG13B. I would do a custom full loop with hard tubing but would only have a thick 120/140mm radiator. My concern was would this be enough to run a full loop? Would I have any overclocking potential?
What things should I look out for/reconsider? Should I just scrap the case for something else?
Thanks!
what case do you think I should go with? I am trying to keep it as small as possible.
I'm a big fan of the case labs s3--though it is a bit pricey. I found a new case called Thermaltake Suppressor F1
I've seen some nice loops made in this case, it is pretty small (only 11 inches on it's longest side), and can hold all my drives.
Thoughts?
