custom watercooling loop, need helps deciding components
Freddy Adhari
36
hi currenty im using corsair carbide air 540. want to upgrade AIO into watercooling custom for CPU and VGA. but im new or dunno about watercooling custom. After googling im consider like EK Full Cover VGA Block EK-FC970 GTX WF3 Nickel, but still can decide about other components like reservoir,pump,fitting. Need some experts person to help me decide the components. sory if bad english xDD
Notes:
I am In Australia And will be purchasing from PCCASEGEAR
AUD
Budget for watercooling is roughly $500 AUD
spec:
i7 4790k
970 g1 gaming SLI
psu 750w
z97x gaming 3.
Choosing reservoir is basically just figuring out what you think looks best (and what fits in your case obviously).
The only real specs for pumps are flow rate and pressure. Generally you don't need a lot of either if you're just cooling a CPU and one or two GPUs.
Radiators are a bit more complicated as you have to consider length, width and FPI (fins per inch). As long as it fits in your case more length and width is better, but FPI is again a little more complicated. Higher FPI allows more heat dissipation, but generally this doesn't automatically result in lower temperatures as long as you have adequate cooling.
So can u help me decide the components?? im using corsair air 540 case.
