Hello I am building a custom case for a i7 7700k massive storage hackintosh machine out of plywood.
My processor will be an i7 7700k of course.
My motherboard will be a gigabyte gaming k7 z270.
My PSU will be a SeaSonic Series S12II 620 Bronze 620W power supply.
I will have 16-32 gb of ram. I was going to put in a 12 sata ii raid controller card (they go for real cheap now) with a bbu or possibly two of them and have 20+ sata 3.5" hard drives .
Plus 2 3.5" dvd rw drives I have many 250 gb to 3TB sata 5400 rpm to 7200 rpm regular hard drives laying around I would like to use.
I will be using 2 m2 hard drives for my main oses mac OSX 10.12 (current version), windows 10, and some version of linux. The graphics card will be whatever I can get cheapest that works with mac osx as I am not a gamer.
I was planning to make the case out of 2 layers of plywood with metal flashing in between them and take an old ATX case and take out the motherboard mounting frame and PCI mounting brackets. Some questions
1. Are PCI and PCI-E mounting cut outs and screws the same?
2. Will having 2 layers of plywood 1/4" with aluminum flashing in between cause any problems as long as I have proper circulation?
3. The metal in the middle should be grounded right? will screwing the mother mounting bracket to it with self tapping metal screws will be enough? or should I ground it directly to the PSU using 10 gauge wire?
4. I was going to have at least 2 140 mm (most likely more) exhaust fans directly connect to the PSU running all the time and then 4 exhaust /' intake fans 120-140mm connected to the motherboard fan headers. Is this enough circulation? Who makes good fans?
5. How would I go about making holders for the 20 + 3.5" harddrives? Are there cheap bays I could buy? Or make my own out of some kind of l brackets?
6. Also what kind of CPU cooling would you recommend? Would taking and old massive solid copper CPU heat sink and attaching some quality fans to it make a good one? Or should I just buy one?
