Customizing right side of Start Menu
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
I wanted to know if there was a way that I could edit and or change the
icons on the right side of the start menu?
Any help would great be great!!!!!
Using Win XP SP2 and all updates
Thx J Hamer
Yes, you can drag icons to and from the 'Quick Launch' bar at will or
right-click them to edit.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| Thx J Hamer
Dave , I was wanting to know if there was a way to replace the icons/ start
menu
.cpl's on the start menu. Like the my documents, my pictures, my music,
my computer and so forth. Not make it where they are not there totally
replace them with different icon and links.
thx again
J Hamer
> Regards,
> | Thx J Hamer
OK this is not the quick launch bar you speak of. There is no native user
defined method to do what you ask.
Regards,
start
| menu
| thx again
| J Hamer
Hi,
This edit may help you:
Add Folder to Start Menu - Replace My Pictures or My Music (line 2, right column)
http://www.kellys-korner-xp.com/xp_tweaks.htm
Anando
Microsoft MVP- Windows Shell/User
http://www.microsoft.com/mvp
http://www.mvps.org
Folder customizations
http://newdelhi.sancharnet.in/minku
Protect your PC!
"J Hamer" <JHamer@discussions.microsoft.com> wrote in message
news:3BC39363-77A4-447C-A38A-5C28EE225C67@microsoft.com...
> Thx J Hamer
