Hi forum,
I have a non-modular PSU, and I cut the extra unused cables off of it in order to make room in the back of my case for cable management. I ended each individual wire with electrical tape in each sleeve, and then I wrapped each bundle in two layers of extra tape. I did this without fully considering the aspects of the modification, and now i'm pretty anxious about using my computer. Can someone link heat-shrink wraps or wire nuts I can use to better insulate these wires? My theory is that if the cables are ended in wire nuts or heat-shrink, they will be just the same as having unused cables in your case, except for the fact that they won't be used ever again. Is this true? If not, how dangerous is this situation for me and my computer?
thanks
thanks
