CX 500 power supply quality
Yes and no, The problem with the CX series is that its internal components are of low quality, so after some time of use it can cause problems. There are plenty of cases here on Toms where that series was the culprit of instability issues, slow performance or even the system not booting at all.
When will it fail could be in a few months or a couple of years, depending how intensive your usage is.
You can use it for now, but start saving up to get a better PSU.
As in explode? Heh no. But it'll just shut down eventually and before that make your system unstable. In worst case scenario it may power surge and fry your mobo at the least, mobo+cpu+gpu at most. I've had the mobo+gpu fry-up once by the psu so I speak from experience, spend extra $$ on a good quality low heat psu, it is absolutely worth it.
Thanks for the help guys, I appreciate it alot. On the supject of power supplies failing, I had a evga 430 watt in this same pc which failed after 7 months of use, didn't damage anything in the pc. In in a acer computer which I used some of it's parts to build my current pc, I was using a 300 watt power supply(not the brightest idea) and after about two months I added the 750 ti in, it died and fried the motherboard.
