Cyber power pc. I removed the cpu cooler yes I know I should put thermal compound back on I didn't hooked it up again and now
Nickc1995
Commendable
May 4, 2016
6
Without the proper cooling things get very hot very fast.....
Not comfortable with "some play".
I suggest that you start over and carefully reinstall everything.
MERGED QUESTION
Question from Nickc1995 : "Need help PC turns on then off"
Yep I removed the cpu cooler to see if the corsair would work. I know I need a little thermal to put on it out after I installed it it was in but has some play in it wouldn't matter it was on it good and now just turns on then off even after sitting for a hour two
