Tech_TTT :
wish you luck with your new PC.
after looking at their site , I found out that they let you choose off the shelve components ... I dont get why every one here are saying negative things about them , you can choose the components you need and I can see they include good power supplies and good components to choose from , not like they force you to get the low Quality items.
We say negative things, because we've seen the aftermath.
Yes, they 'let you' choose good parts.
However, most people buying there do not.
The 'standard PSU' is crap.
The fancy 120mm liquid cooler sounds great, but isn't.
And then all the little tiny addons that you think you need, but don't.
Lastly, the impressive construction quality leaves a LOT to be desired.
DVD drive not connected, CPU thermal paste not applied, abysmal after sale support.
As said...it will work, mostly.
Can you do better? Yes, much better.
