I am tired of replacing the little UPS batteries in my three Cyberpower UPS's. I just replaced one in the CP1000AVRLCD with a 35ah AGM Deep cycle, and it now has about 90 minutes runtime (maybe more). But this caused me to look more closely at some aspects and I am confused.
First, before and after replacement, the Cyberpower Software Powerpanel for Business shows the battery at 20v. It is a 12v battery, it should show about 13v +/-. Again, before and after my change, so unrelated.
Is the software just flakey? Is there some kind of buck converter in front of the inverter that is raising the voltage and measuring that?
After replacing the battery with the large one I ran a test (see the events below). It ran almost 90 minutes but then gave the really strange error "not completed, the battery runtime is insufficient". After all that time.
My guess is the firmware or software is just hard coded to work with tiny batteries, and giving false information. As it is recharging it's got nonsense numbers also, the 42% is probably right, but the 8 minute runtime is nonsense.
Has anyone else hacked Cyberpower UPS's with larger batteries, is there any fix to get the estimates correct, so I don't get alarms that are bogus if it starts to discharge (I've simply turned the shutdown of the PC off, but I guess it might shut the UPS output off incorrectly as well).
Linwood
Linwood
