Cyberpower Mega Special III build help.
LightInfernal
4
Configuring a desktop through cyberpower. Need to know if there is anything im missing, or any, unreliable parts. any help is appreciated. Also, should i overclock 10%?
Gaming Chasis: Corsair Obsidian 750D w/ USB 3.0, Full Side Panel Window
Extra Case Fans: Enermax TB Silence UCTB14 140mm Performance Cooling with Low Noise Profile Fan
Noise Reduction Technology: Sound Absorbing Foam on Side, Top And Bottom panels, and more(1)
CPU: Intel® Core™ i7-4790K 4.0 GHz 8MB Intel Smart Cache LGA1150 (All Venom OC Certified)
Performance Tuning Protection Plan by Intel: None
Venom Boost Fast And Efficient Factory Overclocking: No Overclocking
CPU / Processor Cooling Fan: Asetek 550LC 120mm Liquid Cooling CPU Cooler - Extreme Cooling Performance (Dual Corsair Air Series AF120 Performance Edition Fan (Push-Pull))
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: GIGABYTE GA-Z97X-SOC ATX w/ Intel GbLAN, 4 PCIe x16, 1 PCIe x1, 2 PCI, 1 x SATA Express, 6x SATA 6Gb/s (Extreme OC Certified)
NFC: None
Intel Smart Response Technology: None
RAM / System Memory: 16GB (8GBx2) DDR3/2133MHz Dual Channel Memory (G.SKILL Ripjaws X)
Video Card: EVGA ACX 2.0 Superclocked NVIDIA GeForce GTX 980 Ti 6GB GDDR5 PCIe 3.0 x16 Video Card (Maxwell) (Single Card)
Sli Bridge: None
Freebies: FREE! The Batman™: Arkham Knight Game Coupon
Power Supply: 1,000 Watts - Corsair RM1000 80 PLUS GOLD Certified Fully Modular Ultra Quiet Power Supply
M.2 SATA SSD: None
INTERNAL PCI-E SSD CARD: None
Hard Drive: 256GB SANDISK + 3TB SATA III Hard Drive Combo (Combo Drive)
Secondary Hard Drive: None
Hard Drive Cooling Fan: None
External Storage: None
USB Flash Drive: None
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Internal Wireless Network Card: 802.11b/g/n 300Mbps PCI Wireless Adapter Network Card
Sound: * ASUS Xonar DGX 5.1 Channels 24-bit 96KHz PCIe Sound Card
LCD Monitor: None
Cables: None
Internal Network Card: Onboard Gigabit LAN Network
Fan Controller/Temperature Display: None
Internal USB Expansion Module: NZXT Internal USB 6-PORT Expansion Module
External Wireless Network Card: None
Wireless Routers/Hubs: None
Docking Station: None
Bluetooth: None
Flash Media Reader/Writer: INTERNAL 12in1 Flash Media Reader/Writer (BLACK COLOR)
USB Hub & Port: Internal USB 3.0 4-Port Hub
External USB ADAPTER: None
Operating System: Windows 8.1
Media Center Remote Control & TV Tuner: None
Ultra Care Option: Cooler Master Thermal Fusion 400 Extreme Performance CPU - Thermal Compound Optimized for Thermal Dissipation, and more(1)
Service: STANDARD WARRANTY: 3-YEAR [3 Year Labor, 1 Year Parts] LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
Depends. If you're a confident overclocker then do it yourself. If not, get someone else to do it as there's no point of paying extra money for basicallly a freebie. Plus, I had a i7 build with that Mobo and they overclocked it 10% with a 240mm rad. 6 months later,motherboard blew because of the voltage they used.
