CyberPower Noise Reduction: Worth It?
Garbo86
18
Do you find that the noise reduction options available for CyberPower builds actually reduce noise notably or at all? Here are the items I'm referring to:
NOISEREDUCE1: Sound Absorbing Foam on Side, Top And Bottom panels [+29]
NOISEREDUCE2: power Supply Gasket [+5]
NOISEREDUCE3: Anti-Vibration Fan Mounts [+9]
I'm also getting this:
CS_FAN:Enermax TB Silence UCTB14 140mm Performance Cooling with Low Noise Profile Fan [+39]
And this:
POWERSUPPLY:550 Watts - Corsair CSM Series CS550M 80 Plus Gold Certified Modular Ultra Quiet Power Supply [+62]
Do you think these are all valuable for noise reduction or do you think some of these components are unnecessary because of the quietness of the other components? Here's the rest of the build:
http://www.cyberpowerpc.com/saved/1GE2DL
Thanks!
Tsaran Wrap
I have bought through cyberpower several times they are really easy to get ahold of they have a number on their page and I do know they have a store in Los Angeles California.... but all available info on them is out there as far as getting one in you shop...did they mention they ship......and to the original question yes the dampening does work and for the price...I would be willing to bet you wouldn't wanna spend the time ta do it later.....a favor to yourself would be to do you best to get the quietest machine you can.....
