Let me thank people in advance for help! I also don't want to build my own PC, so don't tell me to do that.
I am building a gaming pc that will be powerful enough to play games for years to come, but on a budget. I was targeting $1500, but I built this one out for $1594 on CyberPowerPC.com with all of the holiday discounts. I currently have an iBuyPower computer I bought off NewEgg and have been very satisfied with it, and I understand that they are basically the same company. I wanted to be a bit more custom this time and some key things I was targeting are a 256-ish SSD and GTX770 graphics card.
I picked the extra fans options and the Enermax fans. The motherboard was picked based on what PC Gamer magazine recommended in the latest magazine I picked up, but I really don't have a clue about motherboards. I also have no clue with what power supply I should run, but I picked a "Bronze Certified" model and 750w. Also, not sure if I should have them factory overclock the system and if I do, go with the 10% or 20%+?
I've done a ton of searches on the individual components and whatnot, and tried to pick parts with good feedback on this site, NewEgg, or other random websites but I am a real novice at this stuff.
I'd love to hear any feedback or tweeks you guys would recommend!
Thanks again!!!
Grimlock
Corsair Obsidian Series 750D Full Tower Gaming Case w/ USB 3.0 & Full Side-Panel Window [+85] (Black Color)
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
COOLANT: Standard Coolant
CPU: Intel® Core™ i7-4770K 3.50 GHz 8MB Intel Smart Cache LGA1150 (All Venom OC Certified)
CS_FAN: Maximum Enermax 120MM Case Cooling Fans for selected case (Maximum Silent Operation) [+29] (1,000 RPM Black Color with No LED Enlobal Magnetic Barometric Bearing 17 dBA)
FAN: Corsair Hydro Series H60 High Performance Liquid Cooling System 120MM Radiator & Fan (Dual Standard 120MM Fans (Push-Pull) [+25])
HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
HDD2: 250GB Samsung 840 EVO Series SATA-III 6.0Gb/s SSD - 540MB/s Read & 520MB/s Write [+218] (Single Drive)
IUSB: Built-in USB 2.0 Ports
KEYBOARD: AZZA Multimedia USB Gaming Keyboard
MEMORY: 8GB (4GBx2) DDR3/1866MHz Dual Channel Memory (ADATA XPG V2)
MOTHERBOARD: ASRock Z87 Pro4 ATX w/ XFast Technology, GbLAN, 2 Gen3 PCIe x16, 2 PCIe x1, 2 PCI [+49]
MOUSE: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
NETWORK: Onboard Gigabit LAN Network
NOISEREDUCE1: Power Supply Gasket [+5]
NOISEREDUCE2: Anti-Vibration Fan Mounts [+9]
OVERCLOCK: No Overclocking
POWERSUPPLY: 750 Watts - Thermaltake SMART Series SP-750PCBUS 80 PLUS BRONZE Certified Active PFC Power Supply [+13]
RUSH: No-Rush Delivery: order will ship in 3 to 4 weeks. 5% off on all orders over $999 must enter coupon code "NORUSH" during check out. [+0]
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: NVIDIA GeForce GTX 770 2GB GDDR5 16X PCIe 3.0 Video Card (Major Brand Powered
by NVIDIA)
Thanks again!!!
Grimlock
