Question CyberPowerPC Kira II power switch LED
Feb 22, 2025
Hello,
I had to replace the motherboard/cpu on my Cyberpower PC (mobo died). It uses the CyberPowerPC Kira II case. I got a newer motherboard from the same brand (Gigabyte) and took note of where everything was connected. The only thing that doesn't seem to be working now is the power switch LED, the ring around the actual power switch. There is a separate small power LED light that does work, and the HDD LED works, all the case fans and LEDs work. The only other thing that was different is that the new processor is using the stock heatsink/fan. The old heatsink/fan had a connection to the motherboard as well as to the RGB controller on the side of the case. The new stock one has only the connection to the motherboard (it has no lights).
So not a big deal at all but if anyone has an idea why this would have stopped working and if it's possible to fix, I'd love to hear it. Thank you.
Perhaps the light's + and - connectors are reversed; you could try changing them.
Thanks. The only F_PANEL leads I have from the case are Power LED + and _, HDD LED + and - and Power SW + and -. Power LED leads to a seperate light on the case next to the HDD led, which is working properly. It's just the ring around the power switch that doesn't light up.
Latest posts
