Hi,
I am going to purchase a gaming machine from CyberPowerPC and I am wondering if my liquid cooling is enough for my system.
Here are the specs
Case: Azza Fusion 4000 Super Full-Tower 2-in-1 Gaming Case w/ Dual System Support, Dual PSU Support, 1x 140mm & 2x 120mm Fans, Front USB 3.0, HDD Easy Swap, 480MM Liquid Cooling Ready
Laser Engraving: None
Internal USB Extension Module: None
Neon Light Upgrade: 12in Cold Cathode Neon Light (Red Color)
Extra Case Fan Upgrade: Default case fans
Noise Reduction Technology: None
CPU: Intel® Core™ i7-4770K 3.50 GHz 8MB Intel Smart Cache LGA1150 (All Venom OC Certified)
Freebies: Intel GRID 2 Gaming Coupon
Performance Tuning Protection Plan by Intel: None
Venom Boost Fast And Efficient Factory Overclocking: No Overclocking
Cooling Fan: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Dual Standard 120MM Fans (Push-Pull))
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: [CrossFireX] MSI Z87-G41 PC Mate Intel Z87 Chipset DDR3 ATX Mainboard w/ Military Class 4, OC Genie II, 7.1 HD Audio, GbLAN, HDMI, 2 Gen3 PCIe x16, 2x PCI-e & 2 PCI (Pro OC Certified)
Intel Smart Response Technology: None
Memory: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory (Corsair or Major Brand)
Video Card: AMD Radeon HD 7990 6GB GDDR5 16X PCIe 3.0 Dual GPU Video Card (Major Brand Powered by AMD)
Freebies: None
Video Card 2: None
Freebies: None
Video Card 3: None
Power Supply Upgrade: * 850 Watts - Corsair Enthusiast Series TX850 V2 850W 80 PLUS BRONZE Certified Active PFC Power Supply
Hard Drive: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
Data Hard Drive: None
Hard Drive Cooling Fan: None
External Hard Drive (USB3.0/2.0/eSATA): None
USB Flash Drive: None
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Optical Drive 2: None
External Optical Drive: None
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
3D Vision Glasses: None
LCD Monitor: * 24" Widescreen 1920x1080 ASUS VS247H-P 1080P (23.6" Viewable) 2ms LED Backlight, DVI, HDMI Input
2nd Monitor: None
3rd Monitor: None
Speakers: None
Network: Onboard Gigabit LAN Network
Keyboard: AZZA Multimedia USB Gaming Keyboard
Mouse: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
Mouse Pad: None
Headset: None
Gaming Gear: None
Extra Thermal Display: None
Wireless 802.11B/G Network Card: FREE! 802.11N Dual Band Wireless + Bluetooth 4.0 Expansion Card
External Wireless Network Card: None
Wireless 802.11 B/G/N Access Point: None
Bluetooth: None
Flash Media Reader/Writer: None
Video Camera: None
Tablet: None
Cable: None
Power Protection: None
IEEE1394 Card: None
Internal USB Port: Built-in USB 2.0 Ports
USB Port: None
Operating System: Microsoft® Windows 8.1 (64-bit Edition)
Media Center Remote Control & TV Tuner: None
Office Suite: None
Games: None
Ultra Care Option: None
Service: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
Rush Service: NO; READY TO SHIP IN 5~10 BUSINESS DAYS
Is the cooling ok for ts machine?
These are the options for liquid cooling. I picked the Asetek 510LC with Dual 120mm Fans (Push-Pull)
Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (All Venom OC Certified)
Single Standard 120MM Fan [-9]
Single Enermax Enlobal Silent High Performance 120MM Fan [+6]
Dual Enermax Enlobal Silent High Performance 120MM Fans (Push-Pull) [+20]
Asetek 550LC Liquid Cooling System 120MM Radiator & Fan (Advanced Cooling Performance + Extreme Silent at 20dBA) (All Venom OC Certified) (Single Standard 120MM Fan) [+9]
Cooler Master Seidon 120M Liquid Cooling System 120MM Radiator (All Venom OC Certified) (Single Standard 120MM Fan) [-2]
(All Venom OC Certified) Corsair Hydro Series H60 High Performance Liquid Cooling System 120MM Radiator & Fan (Single Standard 120MM Fan) [+7]
CyberPower Xtreme Hydro Liquid Cooling Kit 240MM w/ XSPC Rasa 750 RS240, Dual Fan(CPU & GPU Liquid Cool Capable, Extreme Overclocking Performance + Extreme Silent at 18dBA)(All Venom OC Certified) [+54]
Asetek 570LX Liquid Cooling system w/ 240MM Radiator and Dual Fans (Extreme Overclocking Performance + Extreme Silent at 20dBA) (All Venom OC Certified) [+34]
CoolIT ECO II-240 Extreme Performance Liquid Cooling System 240MM Radiator & Dual Fans (All Venom OC Certified) [+18]
CyberPower Xtreme Hydro Liquid Cooling Kit 360MM w/ XSPC Rasa 750 RS360, Triple Fan(CPU & GPU Liquid Cool Capable, Extreme Overclocking Performance + Extreme Silent at 18dBA)(All Venom OC Certified) [+84]
CyberPowerPC Xtreme Hydro II Liquid Cooling Kit 360MM w/ XSPC RayStorm CPU Block,Dual D5 Pump & Reservoir,AX360 Radiator w/ Triple Fan(CPU & GPU Liquid Cooling,Ultimate Overclocking Performance+Extreme Silence at 18dBA)(All Venom OC Certified) [+314]
Here are the specs
Freebies: None
Video Card 2: None
Freebies: None
Video Card 3: None
2nd Monitor: None
3rd Monitor: None
Speakers: None
Mouse Pad: None
Headset: None
Gaming Gear: None
Bluetooth: None
Video Camera: None
Tablet: None
Cable: None
IEEE1394 Card: None
USB Port: None
Office Suite: None
Games: None
