cybershot and memory stick pro problem!!?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: rec.photo.digital (More info?)
bib...@gmail.com Aug 22, 4:49 pm show options
Newsgroups: rec.photo.digital
From: bib...@gmail.com - Find messages by this author
Date: 22 Aug 2005 08:49:20 -0700
Local: Mon, Aug 22 2005 4:49 pm
Subject: sony cybershot dsc-s40 and memory stick problems!!
Reply | Reply to Author | Forward | Print | Individual Message | Show
original | Report Abuse
I own a cybershot dsc-s40 and a MSX512S memory stick pro 512mb. When i
take pictures using the cameras internal hard drive, I can transfer
pictures to the computer fine. However, when I use the memorys stick
pro, the pictures are always corrupted, and when viewing them either on
the pc or the camera, I receive errors. (eg. on the pc, I can see the
thumbnail, but upon opening it in windows picture and fax viewer, it
says 'drawing failed') I have tried formatting the memory stick using
the camera but the problem persists. I can write files to the memorys
stick from the computer fine. Is this a problem with the camera or the
memory stick?
I think you realize that if the card works properly everywhere but in the
camera the problem is where? Does the camera write properly to other memory
sticks?
> memory stick?
Have you checked the manual to see if the mem stick pro is supported?
Neil
Delete delete to reply by email
