D-LINK Internet Connection Problem(HELP)
zkaret011
8
Hey! I recently got a dlink-D93C router. It was working fine until i turned off my internet COMPLETELY and then back on in a couple of minutes(because it was realy slow). Ever since then i have this little yellow triangle with a "!" in the middle and cannot connect to the internet.
I have tried pressing the reset button ONCE, and i have HELD IT DOWN and nothing happens. I have taken the thing out and everything.
Does anyone know anything about this?
Thanks!
I don't have an answer for you here, but wanted to say, if you can't get it work, just RMA the unit
and buy something else.
I recently bought a 16-port D-Link GigE switch. Load of junk. Ran very slow, couldn't maintain
connections, etc. Sent it back, ordered a Netgear instead (should arrive today); cost more,
but at least it will work.
One would think that by now network switch technology should be pretty easy to do (single
chip solution, etc.), but apparently not. Either that or other aspects of these devices are done
cheaply to save money.
Ian.
