[SOLVED] Daisy-chain a pure-sinewave UPS
Dec 5, 2018
I heard long ago that daisy-chaining UPSes could generate equipment-destroying harmonics in the final output.
If one used a pure-sinewave UPS as the first device in the chain and blocked off all but one of its outlets (to prevent overloading), then plugged a second pure-sinewave UPS with a lower overload rating into the remaining outlet of the first UPS, could runtime duration be increased safely?
I'm wondering if the pure-sinewave output would prevent the second UPS from switching to batteries until the first UPS was drained.
This scenario doesn't contradict APC's FAQ on daisy-chaining UPSes (except for not being UL tested).
If you want extended run time, buy a single UPS that can have supplemental battery pack(s). That way there is no question about the configuration being a supported configuration from the vendor.
