Dangerous temps for r9 270x?
Bluething
57
I have a r9 270x 2gb msi oc. The highest temp I've had is 50C. Lowest is about 29C-30C. Average is 35C-45C when gaming. What is a dangerous temp for my kind of gpu? What shouldn't it go over? What should be the temp when on a heavy load? ( No liquid cooling).
You have NO worries to have, your gpu should not go over 80c. If it does then you have to make a fan curve, so as I said everything is normal and you have no worries to have.
Thanks, now I can rest easy knowing my gpu temps are alright! :)
