DAOC/Processor Speed
G
Guest
Guest
Archived from groups: alt.games.dark-age-of-camelot (More info?)
I have just returned to DAOC and was wanting to upgrade to the epansions.
Problem is, I only have a 1 GHZ Pentium III processor, and the system
requirements say 1.4 for the expansions. Does anyone know if my processor
speed is close enough to handle them?
Thanks.
Hi,
You should be able to use SI, but ToA is pretty much out of the question.
SI will probably depend more on your graphics card than on your cpu speed.
if you can improve that, you will go a long way towards avoiding problems.
> Thanks.
David Hall <davehall@u.washington.edu> wrote in message news:<Pine.A41.4.58.0407211435580.261586@homer08.u.washington.edu>...
> Hi,
> > Thanks.
I run ToA on an 800Mhz PIII and It's do-able. Now, with that said,
you're going to want to beef up your machine with as much ram as
possible and a GREAT video card.
