In the dark base pro 900 can you move where the optical drives are? Also can you put fans at the bottom of the case? Finally is the EK-XLC predator 360 AIO cooler a good cooler for this case or is their a better one, or should I use air cooling?
Officially Dark base PRO 900 support up to front all thick size 420mm rad in push-pull and 420mm rad top, I don't know maximum top rad thickness.
Predator 360 will be optimal for CPU if positioned as intake, however, because it pulls warm air from its rad, some open air GPU cooler may effected by, I suggest add three more 120mm fans as pull for the rad (push-pull) so internal case temperature will be cooler.
