Actually I already have the Dark Rock Pro 3 but I still haven't install it because it will block my DDR3 Vengeance ram. I could remove the cover of the ram and there won't be any issues or lift the fan a little high. I haven't tried is so I don't know if it will work.
The Dark Rock 3 has only one fan and is a more compact size which probably won't give any ram clearance issue but what about the perfomance wise compare to the Dark Rock Pro 3? Isn't the Dark Rock Pro 3 overkill?
Should I change to the Dark Rock 3? I'm a content creator so I need good cpu cooling when rendering videos. Thanks.
PC Specs:
OS : Windows 7 Ultimate x64
CPU: i7 4790K 4.0GHz
SSD: Intel SSD 730 Series
HDD: 2x WD Black 6TB & WD Green 1TB
MB : Asus Maximus Formula VII
GPU: ASUS ROG Matrix GTX 780 Ti 3GD5
RAM: Corsair Vengeance 4X4 DDR3 1600MHz (16gb)
PSU: Corsair HX1000
PC Specs:
PSU: Corsair HX1000
