[SOLVED] DARK ROCK PRO 4 with 140mm Silent Wings middle fan possible?
Soni1406
14
Hi,
I am planning to get the DARK ROCK PRO 4 cooler and remove the 120mm fan and use it as a case fan leaving just the middle 135mm one.
I am wondering if its possible to place a 140mm fan in the middle instead of 135mm in case the 135mm breaks?
The warranty is only 3 years and Be Quiet doesn't offer 135mm fans.
If its not possible I will probably get the Noctua NH-D15S for the warranty and modularity.
Standard 25mm thick fan should work fine, adding 2.5mm to the top and bottom doesn't look like it will get in the way of anything. Might depend a little on the frame of the replacement fan. You might have to remove the top cover.
